Keel won’t fully drop
Jan 23, 2014
69
Hunter H26 Peachland
This spring I changed the uphaul rope on my keel. Since I put it in the water the keel will only drop about 2/3 of the way down.
any ideas why this is? Thx.
-na -NA Anywhere USA
Did this happen all of sudden or over time. Rob, let me handle this oone,
What size line did you use and how long. where did you buy the line
No but probably know exactly what happened which is why I responded the way I did but making sure. Heck I helped design that boat.
Yeah on a cold wet day along wth the frog Kermit. Had too many laughs that day. Just waiting till you come back home or do I need to Shanghai you back
Have sent a private message but no response. I know the system and showed rgranger and Kermit along with many others.
Just waiting on a couple of photos of centerboard damage. Want to talk with him when all info is in as I will be calling Canada.
@rgranger. Copy here our session of installing CB line with photos. Thanks
ET, come home!!!! Rob?
Jan 23, 2014
69
Hi Crazy Dave. I replaced the rope with the size stated in the manual. I made sure the knot fit exactly in the hole. However, there was some previous damage to the area where the knot goes and I had to repair with some fiberglass. I am thinking this may be my problem. The keel drops down about 3/4 of the way. Perhaps my glass work was too much?
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
after you did the glass work did you go over the surface with a filler?
@Willemvan
I need to know a response that @splax posted and whether you have any photos of the repair. Also did you route the pins back into the correct holes holding them in place with duck tape? The first question, was the board all the way down when the centerboard line was routed up thru the compression post out to the deck organizer.? When the board was let down, did you hear a clunking sound? It is imperative the board is down with the line run thru the deck organizer. The first turning block should be attached to that line where it exits the deck organizer. Please advise.. If not, is there additional line which you can let that line out. we need to talk. Send a private message with telephone number and I will call.
