I noticed when my boat was pulled for storage - when it was being postioned for the cradle, the keel moved slightly sideways or a "small wiggle". Is this normal?
If you have a swing keel, there is always some play, and you can expect to see some movement possible. If your boat is a fixed keel, there should be no play at all, you may have a problem with keel attachment bolts.
