Keel up or keel down
Jan 23, 2014
69
Hunter H26 Peachland
So, I keep my boat in a marina all summer and remove it in winter. Do you h26 owners leave your keel up or down while in the marina?? Thx. Willem.
This questions comes up every now and again.... and I don't think it is settled (or will be). I keep mine up. My reasoning is that the constant rocking will waller out the pivot hole over time. But I have no evidence to back up my suspicion. Some people think leaving it down dampens the sway of the boat and thus puts less stress on the rig over time.....
YMMV
Nov 6, 2006
10,162
I use to leave mine up when stored in the slip and down when I was aboard in the slip to dampen the rocking. Not on a Hunter, but the concept is the same..
Jul 7, 2004
8,502
Hunter 30T Cheney, KS
"Up" for our Mac26S. Our situation may be unique though. We are on a reservoir and the "cheap" slips are shallow. One time we thought we had enough water under us to leave the centerboard down. We came back the next week and the CB was stuck in the mud. They had let that much water out. :banghead:
:plus:
Jul 5, 2005
219
Catalina Capri 22 Alum Creek Sailing Association
If you have zebra mussels, keeping the keel up at the slip might be a good idea. A dock neighbor of mine had left her C22 swing keel down through the summer, and couldn't figure out why the keel wouldn't come back up when it was time to haul. I'm not sure how she got it taken care of, but I suspect someone had to dive and scrape. Not a job I would want to do at the end of the season, mid October, in Ohio.
May 24, 2004
7,202
CC 30 South Florida
Depending on the marine growth in your area and the frequency of use you may end up with a stuck keel either in the up or down position.
  • Helpful
Likes: rgranger
-na -NA Anywhere USA
Make sure your centerboard line is in good shape so it will not break causing it to come down seriously doing damage
Mar 26, 2011
3,869
Corsair F-24 MK I Deale, MD
Up. There is far less fouling that way, because there is less oxygen, no light, and greater biocide concentration. Also risk of grounding.
If a board does stick , it is always just fouling at the opening, and is easily cut loose with a scraper.
