The dissenting fin-keel lover
Deborah,Without a doubt, a wing keel will let you get closer to shore than a fin keel. I swinger will let you get closer still. However, if you have decided on a Catalina 22, if I were you I would buy the fin keel.For all of the reasons pointed out in other posts, you need to draw little water in the area you will sail in. Notice, however, that the c22 fin only draws 3' 6". This is less than the wing models others have cited.Fin boats sail better than wing boats, all other things being equal. Unless the wing is substantially heavier, the fin's extended righting arm will make the boat stiffer. As it happens, not only is the wing not heavier in the C22, the fin is 50 pounds heavier. This will make a stiffer, better sailing boat in all conditions except lunch time.I'd buy the fin. In fact, when I looked for my Catalina, I did. Of course in Maine, the water is deeper, except where its populated by boat eating rocks.YMMV,Justin - O'day Owner's Web
