I know this has been posted many times but i can't find the posts, but I have found a couple of cracks in my keel trunk, on the port side (inside the forward seat locker). Cracks are a couple inches in length, and located at the forward upper area of the trunk (right in the corner), in front of the (cursed) keel lock.
Not sure how it happened. I haven't hit anything major. I grounded on a mound (an old bridge piling not on the chart !!) just outside our channel last year but it wasn't a 'clunk' impact, just a 'gentle' scraping to a halt. My slip apparently has a cable running from each pontoon which Ii scrape over when docking and has hung me up when pulling out a couple of times (slightly annoying that I have to raise the keel to exit my slip !).
Any advice on repairs, using the West System. I looked on their site and downloaded the manual but no mention of what to do in this area. Do I skive out the cracks and fill and apply reinforcing, or just fill with epoxy ? Do I need to open up the starboard side of the trunk (ie cut a hole on the side of the truck) ? If so, I had a thought to use a 4" hole saw and install a sealable access cover).
Is it safe to sail as is ? (ie wait until end of the season in a couple of months ???)
As usual, assistance much appreciated...
