I have a '76 C22. After sailing last weekend for the first time this year, I found some water in bilge area (near the battery). Since I had a previous rain water leak from the starboard combing compartment (yes I know it's not supposed to leak, but it did!) I sponged it up and forgot it. After sailing in moderate winds on Monday for about an hour, I again noticed some water in the same area. I checked all the usual spots (cockpit drains, volcano fitting, etc.). Finally, when I checked with a light and mirror, and sponged out about two cups of water, I could see some cracks between the hull and keel trunk on both the starboard and port sides. It's located about where the keel hangers connect to the hull (and probably where the major weight stresses are). Water did not seem to be coming in while at the slip, but my supposition is that with the flexing movements encountered during sailing the cracks open sufficiently to allow water in. Has anyone encountered a similar problem, and what was your fix? A 1999 Archives reply from "Pirate of Sha-lin" describes a similar problem, but I could find no place where he described his fix, nor could I locate his email address. Any help or advice would be appreciated.
