Rebedding the whole keel-?
I have a 1974 H-25 on which the PO said he had rebedded the keel. He used 5200. It's a mess outside-- an inch of ooze, easy-- but inside the bilge it looks fine. No rot and no structural faults. The problem is that he says when he last put the boat in, the water came right in through the bolt holes. The boat was immediately lifted and it is still out of the water from that fiasco.I have been preparing to re-bed the whole thing-- lift the boat an inch, lower the keel, scrape it clean and re-fill it. At Cherubini Boat we used what we called mish-mash-- a nasty little recipe of polyester resin, cabosil, and even DIRT-- which could easily hold the whole weight of the C-44's 11,000-lb lead shoe without the bolts (we had it tested). Then my cousin told me all they used on the Raider 33 was 5200, and they faired the outside over with polyester filler. And that keel weighs as much as my whole boat. Hmmm.Who's got experience solving a leaking keel-bolt problem, and what all did you do? After reading these posts I am of the mind to simply Dremmel the outside out, run a good bead of 5200 round it, and back off the keel bolts to ensure they have enough under them too. This keel is only 2000 lbs!!! --it can't be that crucial. Maybe I am being anal-retentive about overkill here.I'll appreciate all informed responses!JC 2JComet@aol.com
