John
Hi guys I want to remove my keelstub wood Ive talked to the guys at catalina they faxed me there fix. And they want me to cut the glass allaround then pell it off. then chisel out all the wood. Then glass in three layers of mat with three layers of roveing sounds easy enough .but when I cut out all the wood there was filler on the bottom It was still sound so I was going to leave it. The wood under the moter was in a bad spot to get at and for now I left some in there becouse I could not get my hand in there and I dont now how far backI can cut without holeing the out side. I drilled the wood that was left and left dryers in the bilge to try to suck the water out. The next problem is that the wood and glass that was removed is about 1 3/4" and the glass that they have me puting back is thin maybe 3/8 " ,with out the full thickness 1 3/4 It look like the washers and the bolts cant be run down all the way becouse they hit the side of the bilge ,and when I add the new glass there will be less room for the bolts.I think I need to build up the bottom with some thing so the bolts can be in the original position .I cant bring my self to use wood .How about star board I think it would take the compression and It should be good in water if It ever got wet again.I guess I could lay up glass and epoxy with filler but that is way more mixing then I want to do.Maybe a ss plate ? If anty body was wondering my PO drilled a bunch of holes in the bilge bottom for pumps and switches and all kinds of junk and nevere sealed them or even put a screw in the holes.He just mounted every thing over the holes.The wood was not rotten but It was soft and the bolts were starting to sink in and crush the glass and they where leaking enough to keep them wet..My hull # is 5112 1988 C30TR and catalina stoped putting wood in the bilge on 5135 I think that I could have gone afew more years with out doing the fix but I wanted to do the bottom next year and this seemed like the place to start.Can anty one heelp me John
