Keel structure question
Jul 5, 2004
3
-Catalina Yachts -Catalina-25 3502 Fairport Harobor, OH
I have a 1987 Beneteau First-305 on both sides of the keel near the bottom is a U shaped depression. Can anyone tell me what this is?
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
An uneducated guess is that it looks like some sort of cover for an access to a locator used for keel installation, or for a lifting ring used during the manufacture of the keel.
That’s the best I can come up with when only halfway through my first cup of coffee.
Gunni
Mar 16, 2010
5,937
Confirm that is the location of one of your keel bolts, and that is a lead keel. Then you will want to look for signs that the keel bolt is loose or wants to be tightened. Typically these are j-bolts, cast into the lead keel. If no red flags I would sail it and inspect annually. For changes.
Dr. D
Nov 3, 2018
282
Beneteau Oceanis 35.1 Herrington Harbour North
Bilge sump. The bilge pump should be located inside that.
Mar 20, 2016
595
Beneteau 351 WYC Whitby
If it is the bilge sump ,you have an issue.You should at least grind a groove and fill it with west epoxy /406.
Did you leave water in the bilge over winter .
DougM
Jul 24, 2005
2,242
I don’t know about the First305 and I maybe wrong about my own boat, a 323, but I cannot recall that the bilge sump extends below the bottom of the hull , not into the metal keel.
Mar 20, 2016
595
It does on the 351/352 and the 35.5 first ,its cast into keel and the glass goes down into the casting,however its more forward
