My keel-stepped mast undulates when the wind picks up. When it does, it bangs into the cabintop inside the hole. It's probably been doing this 30 years, so I guess it doesn't hurt anything. It's just irritating, and raises the anxiety level in a blow. Also, if it's working the mast, rigging, and mast base, I don't see anything good here.
I stuffed a rag up in between the mast and hole, which eliminated the noise problem and much of the vibration. However, the remedy is hokey, and the rag eventually drops out from movement, requiring re-stuffing. I'd like a permanent fix. Has anyone ever addressed this? Fiberglass? an insert? etc?
