Inspection is key to detection
Greg,MacGregor recommends lowering the keel (ANNUALLY if left in water) to inspect the keel bolt and keel bolt hole for wear. This is very important since if the bolt fails either on the trailer or in the water, the hull WILL be damaged.That said, the fit between the keel hole and keel bolt is not perfect. It can be improved by installing bushings (inserts) for the keel (not a DIY job, unless you're a machinist!). Be sure to use a material that is strong, self lubricating and won't cause corrosion problems when in contact with the keel and keel bolt.See the Generic Venture Manual on this site. http://www.macgregor-boats.com/Also there is a V21,23,25 manual. All manuals on this site mention the keel lock-down bolt required for self-righting. I find it troubling that your boat doesn't have one. Mark Steinbeck's 1968 V21 (hull #175) has one.http://www.northcounty.com/sailing/v21/project_list.htmHappy sails *_/),MArk
