I Have a Winged Keel
When we set out to purchase a Cat. 30 we were intent on getting a wing keel model. We now own a 1988, with tall rig and the winged keel. Our rationale was simple. We plan on cruising the ICW in a year or so and want to increase the number of places to anchor! Its not an issue of performance at all, but the advantage of wing versus fin. I think the wing does just fine for us in a wide range of wind speeds and sail configuarations here in inland Georiga. The draft of the Catalina was critical and I speak from experience. Back in the mid-80's we cruised and lived aboard a Coronado 35 sloop with a 5'6" draft. We ran aground all the time trying to get in close to great anchorages, but wound up hanging farther out unprotected in the weather. I was convinced that we were just to deep and I vowed that if I did the ICW again, it would be with a shoal draft boat. Even more so now that the Army Corps is slow on dredging inlets and some areas are well documented as simply, "shallow". I learned kedging was the best way to get off a grounding with a fin keel, but I also feel confident that running aground with a wing is not as serious as some would believe. Kedging to beam....certainly, but the vessel should pivot well on the wing and come off easier at the bow. When weighing the risks, I feel the wing would give you greater peace of mind when cruising shallower water then the fin. At 3'10" with added weight built in to compensate for the draft, if your not planning on extended open water passages, the wing is an excellent vessel for coastal sailing.Good LuckBob"Breezin II"
