Keels
JT-Before you go cursing your boat for its iron keel try fixing it one more time. I redid my keel last spring and I hauled it this fall without rust except where I grounded it and scraped off the coats. Can't blame the iron for my failures to navigate competently.
While your are probably pretty dejected about the prospect of doing this again, you also probably don't have as much work to do. The rust is most likely pretty superficial, and there is probably not a lot of scaling. So, stripping it down again isn't going to be the nightmare it was last time. This time, after you strip it try this. You probably already know some of these steps, but I'll go through what I did top to bottom anyway.(On fixed keel boats) Remove the bottom paint for three or four inches on the keelson all the way around the keel to hull joint. Grind back to fresh gel coat. The goal is to create a strip of clean hull so that when you coat the keel in epoxy you can overlap on to the hull for a good joint.Grind and sand the keel until as much rust as possible is gone. Don't cheat and leave the areas where the paint didn't come off; it'll cost you in the end. Wear proper protection and take care with your residue. After you've removed as much rust as possible with the grinder, use naval jelly or the equivilant to remove the remainder. Wash with fresh water and coat with a metal-lock type primer immediately. If you wait overnight you will have to prep it again.Using Interlux Fiberglass wash or similar wash down the area of hull you washed earlier.Mix up a batch of epoxy, my preference is for West System. Paint the keel with the epoxy. Make small batches and paint small areas, and then another small batch and small area until the keel is coated. If you haven't worked with epoxy before, there is no magic to it, but you don't want to make big batches because the will get very hot as they cure in the cup. Paint the entire keel and overlap onto the area of hull you've stripped and prepped (on fixed keel boats).The hardest part of this is to figure out how to get either the bottom of the keel, on fixed keel boats, or to drop the board and get the top of the blade with swingers. You're on your own here. I found that I could get to all but a couple of inches on the bottom of my keel and had to content myself with that. This spring I will finish the job because the boat is blocked differently.Once the epoxy has started to cure (its sticky but not still wet) paint another layer on. It is important to do this while the previous layer is still curing because later you will have to reprep because of the waxes that are released at full-cure.Once the second layer is in gel phase, I would mix up a batch of epoxy with fairing compound and spread it on the keel. This is not necessary for rust prevention, but fair keels are faster and point better. Go with a thin layer of fairing mix and add another layer in its gel phase. When they've cured, sand the keel fair. Finally, bottom paint.At this point you have a solid layer of plastic around the keel. If you've prepped correctly, you won't have to do this again for a really long time. Also, if you've gotten good adhesion, even if part of the coat falls off, only that are will be affected and you can repair it the next year. Justin - O'day Onwers' WebI am assuming he
