Lot of work with grinder
I did this last summer using a grinder with a wire wheel. Definitely recommend long pants as well, because those little wire continuously break free and stick in your legs like miniature arrows.If I had to do it again, I'd surely rent a sandblaster. It's gotta be a lot easier. The grinder brush works, but it's a very tiring and lengthy process because the brush covers such a small area. It was a lot of work, and if not painted over right away will be rusted over again my morning.I applied a special marine metal primer by Petit to the freshly bared metal. My keel was very pitted, so I opted to faire it as well. At first I used an epoxy putty. Not only was this terribly expensive, but it was very hard to work with as well. I ended up fairing most of the keel with a fiberglass epoxy resin using a structural filler to give the resin greater strength, thickness and density. It was my hope that all this work would prevent the keel from oxidizing so quickly when in the water. Some spots would oxidize quickly, black spots would form, allowing more of the metal below to further oxidize, only to dissolve away in a black particle cloud when scrubbed under water.It's been 16 months now and the keel looks perfect. No oxidizing coming through, no bare spots, no sections of my fairing breaking away; still smooth. However, my boat has only been in the tropically warm waters of Key West all this time, so I don't know if vast temp. changes would make a difference.The details and photos of my bottom work can be viewed at the link included here.Scotts/v RubiconKey West
