keel prep plan. is this good?
luvitt
Oct 30, 2008
297
na na na
i was gonna prep my keel this past weekend, but the boatyard guy didnt give me my free can of seahawk 1277 until today. but I've been doing some research. can you offer advice?
my bottom job was new when i got the boat. the paint job is tight. hardly any chipping paint. The keel was faired and looks good. but sitting over the past year i got a little rust on the keel. just surface rust that I can pretty much touch and it falls off.
I pressure washed the bottom and keel and got the loose stuff and chalky paint off. I plan on going over the keel with a wire brush.
A boatyard neighbor came over and was talking with me and suggested i Ospho the keel and said it didnt need much work. he is a professional capt working on 60' cat getting ready to charter in bahamas in May. He said just wire brush it, Ospho it, and paint right over it with antifoul.
I was thinking I would do a little more. Tell me if im on the right track.
1. wire brush it
2. leave the tight, intact, bottom paint on the keel
3. barrier coat over top of existing scheme with seahawk 1277
4. two or three coats of seahawk cuprikote antifouling (got 4 gallons from the same boatyard guy for $100!)
i do see some kind of compound showing through the bottom paint, obviously what they used to fair the keel.
oh, can I prime it and leave the bottom paint off until I get closer to splash?
Thanks!!
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I'd use the Ospho... IIRC, it will convert the rusting metal to Iron Phosphate, which will stop the corrosion process and protect the underlying metal...
Oct 22, 2008
3,502
Wire brush the metal... coat it with ospho... prime it with an epoxy barrier coat...then paint it.
The step where you prime it with an epoxy barrier coat may not be necessary, but I'd do it anyway. :)
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Strip it to bare metal
Use a belt sander and a disk sander in a variable speed electric drill. Remove all bottom paint and primers until you get to bare metal. Not a single trace of paint. Then whip up a batch of west system epoxy. Epoxy coat the keel. While the epoxy is still liquid, use a wire brush in your electric drill to work it into the keel through any oxide layer that developed since you sanded off the paint. Do a final coat and smooth it out, Aloow to cure overnight. The next day while the epoxy is still cross linking and reacting epoxy barrier coat the keel with a couple coats of barrier coat. This hopefully will react and bond with the West epoxy and provide a strong foundation to prevent oxidation (rust) of the keel. After the barrier coat dries, rough it up a bit with sandpaper and then bottom paint it with a color you hate. Then bottom paint it with two or more coats of a color you like. All set for two to three years.
