Pin removal
I removed my board last year and in the process, I saw the pin ends were champhered to conform to the hull sides. In this slightly flattened section there was a hole drilled and countersunk for a flat head screw (mine were #8-1") which seemed to be a minimal for retention. I have had concerns since then about the pin size (1/2"), the screw size, what and how much material is in the hull by the pin, and the amount of metal on the forward edge of the board by the pin. If I do this piece of work again, I will probably redo the board with a SS center plate and pin shaft.
