Calibrating sounder
Easiest way I know to calibrate is measuring how deep it is right at my dock by dropping a leadline to the bottom and measure from the bottom to the surface. I do this as close as possible to area where transducer is installed. You can then go and calibrate the unit to show exact depth from water level to bottom. I generally calibrate with the "pilot's foot" substracted, meaning the unit shows one foot less water than reality. That way, when I pull in an anchorage or sail in shallow water, when I get fidgety, I am still safe. Of course, you've got to know your draft. My former 28.5 was 4'Using my method, if I moved into an area that showed 5 feet on the unit, it meant that I still have 2 feet of clearance below the keel (5 feet shown less 4 feet draft plus "pilot's foot").That way provides me with a little safety when in an unknown area (or in a panic situation)
