I have a copy of the older manual and it doesn't seem to match the configuration of my Macgregor Venture 222. (see picture - front of boat is to the left) I assume the bottom left bolt is the pivot bolt (no back access)? Is the middle-left bolt the lock bolt? If so there is no access from the back side of the trunk (and thus no visible nut). Do I simply unscrew this middle bolt to prepare to lock the keel? The top middle bolt has access in the back and also holds the cabin divider wall bracket. Does this top bolt hold anything regarding the keel (like the rubber bumper?)?
Thanks much from a new user.
