We own a 1980 Hunter 30 which has persistent water in the bilge. After haul out last fall we noticed a crack in the forward end of the sealing compound joint between the hull and the keel. Could this crack be the source of water coming into the bilge? If so, what is the procedure to seal the crack? It is hairline now, with the boat on the hard. No sure how big the crack is when the keel is not supported from underneath.
Has anyone had this problem? How did you do the repair? Any advice would be greatly appreciated!
