keel/hull separation
3
beneteau 351 Subic Bay, Phil.
Hi all, im new to the forum and i'm in the process of purchasing my first boat, i use to sail hobie cats.. im current looking at a 351 and had it surveyed , there is a separation at the trailing edge where the keel meets the hull, just about 4 inches long. The previous survey noted that it was normal for beneteau boats to have this separation due to lateral flexing and that there is nothing to worry about is this true? thanks in advance
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
I had the same on my 352. The surveyor I had said the same thing. No water was coming in and the keel nuts were tight. He sugested that while it was on the travel lift, fill the small gap with 5200.
Jul 3, 2004
11
Beneteau 375 Windsor, Ontario
I have a First 375 that did the same thing.You wlll find that the keel extends quite a distance past the last keel bolts and it tends to separate at the back.
While the boat was in the slings I dug out the old calking and filled the cavity with 4200. That was 3 years ago and it hasn't separated again so far.
Oct 27, 2008
16
Beneteau 38 marina
This is great information. I have a 38m and also noticed this gap/ 3~4 inches that went well past the bolts. Was worried when had a haul out and saw in it in the sling Had some 5200 put in, no sea water entering. Thanks
Apr 27, 2010
968
It shouldn't extend well past the bolts. We're talking about a 3-4" long small gap on the trailing edge of the keel. Unless I'm not reading your post right?
