C
catherine
I have a 1991 First 285. This year when it was pulled out of the water, it had a small but noticeably different gap between the keel and the hull. The marina says that their attempts to adjust the boat position won't close/narrow the gap. They are suggesting that the keel be dropped, the keel/hull joint be prepped and re-bedded and the keel re-installed.
We have never had water leakage in the boat. Before I give the go ahead, I wanted to know 1)if any other 285 or similiar boat has had to do this and 2) if so, do you know what caused the problem? I am not convinced that all of this is necessary but I also am concerned that the gap is there. Any comments would be appreciated. Thanks.
