Keel/draft
7
Catalina Std. rig Home Hug's Landing
2nd attempt.
I have a '81 Catalina 25 with 4' draft. I was wondering if it would be cost effective to swap keels out to the newer wing keel. That would give me the 3' draft that I could use to bring the boat home. Is it possible?
Thanks,
Hugh
Nov 7, 2006
28
Hunter 30 Pasadena, MD
2nd attempt.
Thanks,
Hugh
I would suggest you take the question over to the Catalina 25 250 Capri 25 owners forum at http://catalina-capri-25s.org.
Next to the factory, they are probably your best source of information for all things Catalina
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
Short answer - yes it is possible. Most of these keels are bolted on/caulked in with something like 3M 5200 so the job would be a MAJOR pain; not to mention the cost of the new keel. If you're lucky, you might find a wing keel from a salvaged boat.
Here is a link to Mars - a source for new keels: http://www.marskeel.com/keels/10
However, you'd be better off finding a different boat that meets your needs.
