Ah, but...gentlemen don't sail to wind.
I found from racing over the years that tacking through 90 degrees is about normal, race boats can sometimes tack through 83 or so degrees. I've seen lots of racers work hard at moving the jib clew inboard, and go from 135% to 155% jibs, use Sobstab's and NorthSail's latest and greatest sails replacing them every year getting them cut so flat that they had no draft. After all that, they end up trying to point so high, that they end up crabbing sideways, making the degree of set, out of sight. It was so enlightening seeing this from the racing committee boat after having been out there racing for years too. The best sailor I know (and has literally thousands of trophies) was always telling me to 'drive it down', I was crabbing too.
In summary, if you're able to point 45 or less degrees to wind, that's good enough for me. But, I'd rather sail off the wind so it's even possible to go into the vberth without having to push down from the cabin top so I don't go airborne. People think it's funny or an exageration that the boat beat's you up, but no, it's for real, go upwind in 30 knots for three days and see if the boat just doesn't bruise and cut ya. I've spent a lot of money re-doing, upgrading, and repairing/replacing all kinds of stuff on Renasci, but I have the original JSI sails built in St.Pete some thirty years ago, and I'm not ready to replace them yet. They have good stitching, but I'm keeping them with what decent draft they do have, instead of trying to flatten them so I can go to wind better. Keeping a good amount of draft in them helps with lighter air days sailing slightly off wind. You can smoke your competion by doing that by the way, but only in light air.
And, I wanted to add, that I have the shoal draft keel, and I can carry a full set of sails in up to 22/24 knots, then I furl the jib. I had it out in 30 to 35 knots of breeze with the staysail and a reefed main, and they still pointed me within 45 degrees of wind. If you're interested in doing fiberglass work to bring the jib clew inboard, then you need to start cutting holes in everthing down below and start sanding off fiberglass everywhere possible to reduce weight, and start working on a keel. But, don't let the local PHRF committee find out, they'll probably want to and with good justification, hit your rating like crazy.
But, if you can tack within 90 degrees and have to go up wind, then you're in good shape, just ride it out. The amount of time and money you'll spend will increase exponentially for every degree earned.
Okay, enough pontificating for one evening......Happy sailing.
Kb
