Hi, I agree with Larry, that is a nasty crack! We had a similar repair done due to a yard moving our boat while we were gone and blocking the keel fore and aft with no support in the middle. As you can see in the diagram that Peter sent there isn\'t a whole lot of structure behind the ballast. As it was our glass got a nasty wrinkle just forward of the rudder shoe. We had to cut out about 6 inches of glass and repaired it as Larry described. Looking at your pictures I have to ask if you are sitting on 3 blocks or 2? Walt, Lyric From:
AlbinVega@yahoogroups.comTo:
AlbinVega@yahoogroups.comDate: Sun, 18 May 2014 03:14:43 +0000Subject: Re: [AlbinVega] Keel damage & water in the keel
Hi there, That is a nasty crack, you want to keep your boat out of the water and let it dry out. If it was my boat, I would strip the entire keel and see if there are stress cracks above this nasty one below. Did you get a chance to look inside where the keel and hull ties together? If you find cracks or any cracks at this point, you want to strip this area as well. I would really support the keel right now, don’t let it hung in the middle as to say. This is a pretty easy fix all in all. But you want to really look for all damage. I am not sure if your keel is filled with iron or lead? You might want to find out which you have. I am thinking, a crack that big, and water getting into the keel…and if it is iron, you want to stop that rust now. I think you are going to want to cut the fiber glass below and above this crack first. You will probably hit resin and sand passed the fiber glass, they sealed or set the iron in place by pouring this resin and sand mixture in the keel. Once you open up the keel, look for cracks in the resin …sand in the keel. This stuff is as hard as rock. Grind this resin and sand somewhat flat and apply your resin and fiber glass right to this. You will also want to tapper all edges of the fiber glass you cut out. When you get start send me a note and pictures, I will tell you how I made these kind of repairs. Larry Sent from Windows MailFrom:
AlbinVega@yahoogroups.comSent: Friday, May 16, 2014 2:20 PMTo:
Hi,I have just bought a Vega 1203 and upon final inspection today I saw water dripping out from below the keel. It\'s coming from a void inside the keel below the big drain plug.This Vega actually have two drain plugs and the damage is to the lower chamber.My question
o I need to be worried about this? Is immediate repair necessary or can I wait until winter?It looks like the keel has ht a rock or something - there is a 10 inches scratch on on where the water comes out.ThanksBr Jesperhttps://www.dropbox.com/s/piyt4jmzidx2oa3/image.jpgskade_koel.jpg skade_koel.jpg Shared with Dropbox View on
www.dropbox.com Preview by Yahoo
