Do some searching on the various sailboat forums. West System has a paper on how to fix it as does Catalina Yachts. If you have an early boat of the first design then you probably have wood in the hull to keel joint area. You might need to dig that out and fill it with a hard substance, install new bolts and then fix the "Smile".
