C
Chuck K.
Hi List,Well, it finally happened! While sailing this afternoon on a low tide, bumping bottom several times, and after cranking the keel up and down several times, my keel cable snapped. I'm now kicking myself for not replacing the cable while the boat was hauled after I purchased it this spring. I plan (hope?) to replace it while in the water by diving beneath the boat to remove the old cable at the keel, attaching the new one at the keel, and threading it up through the thru-hull and hose to an assistant inside the boat for attachment to the winch. Has anyone tried this method? If so, can you give me any tips, or things to watch out for? I plan to take it to a quiet, deeper bay to do the work. Is this all wishful thinking on my part? Is it worth the cost of a short haul to avoid this aggravation? Any comments or suggestions will be appreciated. Thanks.Chuck K.Doo Dad (12418)Merrick, NY
