The horror ......
The emotional scars are healing, but it’ll take time and a fair amount of beer to put that episode behind me. My 1974 C27, with lead keel had bolts that were dangerously rusted. The actual threads crumbled off while I was examining them. Like some of the others posting here, the wood stump was rotted and had to be chiseled out on top of everything else. Basically, I rebuilt it with fibre glass using the heaviest matting I could get. Then did the windowing thing and drilled new holes. If you have the lead keel, here’s a handy hint. When you’re drilling into the lead, use soapy water down the holes, otherwise, the drill bit will bind in the keel. The lagbolt upgrade works, but find a friend who has an impact gun, I first tried using a ½” drive powerbar and nearly died. Another handy hint: after you’re done and you’ve sobered up a little, paint the bilge with cheap paint. The lower grade paint will protect the aria but will also act as an early warning system when the bilge requires attention again.Just keep reminding yourself old boats run on air, love and hard work. Around a month after you’re done the nightmares recede a little, but you still wake up screaming and crying from time to time …..Later, eh!Ferg
