Keel bolts/rudder autopilot?
8
Islander I28 Kemah, Tx
I am new to sailing, I have had my I28 for about 6 months and have noticed that my keel bolts are corroded but it seems to be only surface corrosion I grinded on them a little and the corrosion seems to be about a 1/8 of an inch or less thick is this an issue? Also what is a good tiller autopilot for this boat.
Scott
Jun 9, 2008
1,792
- -- -Bayfield
I used to own an Islander 28 and had a tiller pilot by AutoHelm. Worked just fine and the install was super easy. It seems that 1/8" of deterioration on your keel bolts is a bit much. Are you saying that you cannot move the nuts on the threaded rod because of material has corroded away?
Dec 24, 2009
8
Well the nut appears to be ss so it has no corrosion, I didnt try and turn it but took a dremel and with the grinding bit ground a little bit on the tip of some of the bolts and right away saw shiny steel underneath it could have been a 1/16th of an inch I really just geussed. I love this boat to death and want to keep her in the best shape possible. She is really easy for me to sail by myself and I have done so even in ROUGH weather like 30 knots sustained with gusts up in the 40's and I maintained control of the boat. I want to keep her and do some long distance stuff because of the confidence I have in her.
scott
