I recently purchased a Bavaria 47 2001. After a few months of preparation, we were ready to leave from Port Antonio Jamaica for Willemstad, Curacao. The first leg of our trip from Montego Bay to Port Antonio went without any problems. Upon leaving Port Antonio,
within 30 minutes, my wife screamed that we were taking on water. It was to the floorboards and splashing around. Inspection of Through-hulls, seacocks, the rudder, the saildrive, the bow thrusters and all connections to the belly of the beast revealed nothing. All seacocks had been closed prior to departure. the closed floorboards revealed that water was coming in in the boxes containing our keel bolts. When this was discovered, we were in 10 to 15 knot winds with 3 to 5 foot waves, nothing bad. As soon as we righted the boat, the ingress of water seemed to stop.
I found out that in 2004 or about that time, Bavaria changed their sealing process, from an epoxy glue to 3M 5200 which not only seals but also has some memory to compensate for the flexing of the keel.
This is the process I would like to use. I have tried to remove the keel by removing the nuts and using a tractor to seperate the keel from the hull to no avail. I will be using wedges to separate them.
A word of caution: at the time my bilge pump did not do its job because the water did not stay long enough in the bilge for it to prime. Second, I came to realize that some holes were made between the baffles and water got into those which sends the water behind the structure. With a hand pump and a small tube we were able to remove most of it which turned out to be in the neighbourhood of 50 gallons.
Does anyone have thoughts about the material I should use to rebed my keel to the hull? Has anyone encountered the same issue with a Bavaria? This is the first time that I have seen this kind of problem with a modern boat.
Thank you in advance for your help and advice on the procedure.
