Keel bolts gone, but no crack (yet)
john mal
The keel bolts are totally rusted and breaking apart. Bought new bolts from Catalina. It has been suggested that 1/8 inch layer of fiberglass be chipped away to get rid of (possibly) rotted wood between this layer and hull. Anyone have any experience with this problem. No crack on hull.
John
check the wood
I think that if your bolts are rotted your keel stub is rotted and should be replaced catalina has a fix it sheet on the keel stub but the wood is about 11/2 thick and needs to be cut out then you need to put thick roveing and mat glass on the bottom of the bilge and up the sides about 6" then drop in the bolts John
Roger
We just finished our keel bolt repair
We just finished a keel bolt repair on our 1978 30-foot Catalina. We used 8-inch lag bolts ordered from Catalina, a long drill bit (Catalina Direct), and some 1/4-inch thick stainless steel washers custom-made by a metal shop. Instead of removing the entire keel stub (wooden layer), we had some advice from Catalina for a modified procedure: using a hole-saw on your drill, drill a 1-1/2 inch hole wherever you want to put a new lag bolt. After drilling a pilot hole, drill carefully throught the upper layer of fiberglas and then through the layer of wood. Avoid drilling into or through the lower layer of fiberglas (the hull!). Clean out and dry out the hole, and fill with fiberglas. We also cleaned/scraped the bilge, and put a layer of fiberglass on the bilge bottom to cover all of the new fiberglass "plugs". Mark the plugs to make sure you can find them when the fiberglas has cured. Then drill through the fiberglas plugs and hull, into the lead keel. Install the lag bolts with washers. In our experience, you may drill into the existing keel bolts, because they are turned and run horizontally in the keel. In that case, measure the depth of the hole until the point where you hit the old keel bolt, then cut off the end of your lag bolt accordingly. We now have 5 new lag bolts installed, two of which had to be cut down to about 6 inch lengths. With this modified procedure, the lag bolts/washers are secured through a thick layer of solid fiberglas, and are not in contact with the keel stub (wood). When completely finished, we covered the lag bolt heads and washers with a further 1/8-inch layer of fiberglas.
Jan 20, 2006
39
- - on Great Bay
My bolts were okay but I tore out the wood.
. My bolts were still usable but the plywood in the bilge was rotten and had to be removed. First I drilled into the bilge floor to check it. It was obvious that the wood inside was wet, black and rotten. I used a 2 inch and a one inch hole saw to remove the fiberglass by cutting as many holes in it as I could. Then it was fairly easy to chisel everything out. Then I layed in three layers of heavy matt and roving running the final layer up the sides. It came out great. I just painted it gleaming white this afternoon.
