Keel Bolts for a 1999 Oceanis 461
Oct 6, 2022
2
Beneteau Oceanis 461 Norfolk Va.
Good afternoon to all ..... I have had my 1999 Oceanis 461 for about 2 years now and wanted to check the condition of the Keel Bolts. Unfortunately, with Beneteau having shuttered the Carolina factory I am having a really difficult time trying to find the correct torque values for these bolts so when we re-install them, we get them snugged up properly. I sent an email to Beneteau USA and got absolutely no response. Any info would be greatly appreciated.
Jan 7, 2014
455
Beneteau 45F5 51551 Port Jefferson
I got the pdf from my local Beneteau dealer, Willis Marine, Huntington. He was very helpful, the local dealers are still a great source.
APP314
Jun 10, 2018
8
Beneteau First 38 Herrington Harbour
Hi Michale,
I found virtually impossible to apply the required torque (120- 260 Nm or about 100-190 ftLb) given the limited space available to fit a long enough braker bar. I solved this by using a torque multiplier. In case you run into a similar problem here is a link
(https://smile.amazon.com/gp/product/B0017K5ARU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1).
You need to divide the torque value by the multiplier ratio if using a torque wrench.
Alejandro
