keel bolt torque
G
greg
What is the correct torque for the keel bolts? It looks like I have 4 heli-coils in the weldment. The keel has quite a banana shaped curve in it.
john renfro
bolts
hello greg, the CATALINA DIRECT OWNERS HANDBOOK under routine maintenance, section - don't over tighten the keel bolts, reads, " use no more than 30 foot pounds". i am using 20 ft.lbs and checking after each outing if they loosen up, i will add a few more pounds of torque up to the max of 30ft. lbs. john
