keel bolt removal
james wlkinson
I have an oday mariner 2+2. For two years now I have been trying to remove the keel bolt with no sucess. I can remove the nut and get the bolt to spin freely. However no matter what I try the bolt will not back out. AM I missing anything???
W
win
Have you tried
taking the load of the centerboard off of the bolt and then trying to drift it out? aloha, win
james wlkinson
thanks win
already tried this for several hours and have had no luck
Justin - O'day Owners' Web
Cut it?
James - I assume you have a concern with the keel or you wouldn't be trying to do this. If so, I might try to cut it, though you're committed to a repair at that point if you do. Can you trap the bolt so it doesn't spin and get a dremel on it? Justin - O'day Owners' Web
Dale Weston
Removing the centerboard bolt
I have just been there and finally got it out. I am assuming that you have removed all the nuts and washers and plates and rubber thingys from the centerboard trunk. I messed around quite a while before getting any where. It may help you to know what is inside (something that I didn't know until the board dropped. The hole in iron centerboard has a bushing in it. The threaded stainless shaft goes through this bushing. So - - the shaft spins freely, but the bushing and shaft are stuck together and need to be unstuck. I believe my "secret" was "KROIL" a really good penetrating oil for getting into impossible places. The magic steps are: Squirt the stuff in the holes from both sides. I aimed along the top of the shaft. I also relieved the weight on the centerboard by pounding a wedge of wood between the centerboard and the trailer roller. Then I threaded a nut back on each end of the shaft so that I could beat on the end of the nut and not damage the shaft. I just used my standard claw hammer and tap tap tapped on one side, and then on the other and then squirted oil and then tap tap tapped. I a short time noticed some movement. The first time it was only about an eighth of an inch - then more oil and more tapping. Pretty soon . . . Bingo! I used the tie the stern to something solid and slide the boat back method to free the board. It worked. I am now beating rust and deciding what to do next. If you've already got yours out, what are you doing with it / or plan to do with it? Hope you get yours going, Good Luck, Dale
