Keel bolts
If your keel bolts are rusting, they aren't stainless. Catalina, for some reason or other, used mild steel keel bolts in some of their older Catalina 25's and 27's. Not sure if your boat is one of them, but Catalina used to sell some sort of keel bolt upgrade package that essentially involved drilling parallel holes in your keel and installing stainless bolts.In any event, you could do a number of things to try to kept your current bolts from rusting. You might try cleaning them up with a wire wheel, fine sand or emory paper, bronze wool, etc. Once clean, "paint" them with either epoxy or a zinc chromate paint like "Rustlok." FWIW, I know of no old Catalina that had its keel fall off due to the use of mild steel bolts.
