Ron Brassord
I am getting familiar with the quirks of my newly acquired 88 Catalina 30, and traced the bilge water to a weeping keel bolt. It's in the middle on the port side, and is a slow trickle, not enough to worry about ,but I'd like to fix it. I am wondering if it would be prudent to back off the nut, and put a larger washer with a bedding coumpound under, and retighten the nut? I did get a 1/4 turn on the nut, but it still weeps. The boat was just sailed home over 100 miles in moderate to heavy seas. I would think it should abate completely after the boat sits and the source of the leak fills? I also got some slight tightening of the other bolts I could reach with a stilson. I intend to give all the bolts a torqueing to 50 pounds as soon as I can locate a deep and large enough socket. The more I get into her, the more I like her Ron Brassord Lighthouse Point Fl
