My 1984 Bene 35' First is in dry storage for the winter (from fresh water). I pulled all of the keel bolts and looked them over. Each bolt is in good shape. There is a little corrosion on the head of the bolt that was exposed to bilge water, but nothing significant. The threads are in pristine condition, with the threads being shiny/bright metal. I cleaned out the caulk in each bolt hole and am ready to clean up the bolt heads, washers and plates.
I noticed that the square plates (about 3" on a side) are cupped up away from the hull. I am wondering if this they should be flat in order to distribute the load. Are they cupped due to the keel forces pulling down on the bolt heads? Should the plates be flattened or replaced? Or are they OK as is?
In addition, I attached a table of torque values to apply to keel bolts. I found this table some time back on another, similar thread. The table gives values for bolts made from various materials. I am assuming that the Beneteau bolts are not stainless steel, since there is corrosion on the bolt head. Am I correct? There is a wide range of torque in the table from the minimum value to the maximum value. Should I try to torque the bolts to the maximum value or hit somewhere in between min and max?
Thanks in advance for your help.
