Keel Bolt Cleaning
Apr 14, 2010
195
Jeanneau 42DS Larnaca Marina
I want to clean and re-coat my rusty keel bolts and nuts. The SS backing plates are like new! What is the best method of cleaning them and re-coat them? Wire brush? Naval jelly? It looks like its just surface rust since the boat is not that old and the bilge is dry. Any advice from experience will be appreciated. Thanks.
7,599
Alden 50 Sarasota, Florida
If they are rusty, I’d suggest you remove completely one nut at a time and inspect the hidden threads to see of you have a cosmetic problem or a bolt rust problem.
if the former, don’t use a steel wire bush as that will only contribute to the problem. Bronze or brass brushes are preferable.
Jan 4, 2006
7,443
The best method, if you can get in there, is to go at it with a Dremel and SS rotary wire brush. Given a perfect world, you would do this job while on the hard.
What do you plan to re-coat them with. Nothing really comes to mind.
Apr 14, 2010
195
Some kind of epoxy paint i hope to find.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
If they are stainless, just leave them bare! The oxygen will help them retain their corrosion resistance.
Likes: Dalliance
Bob S
Sep 27, 2007
1,808
Beneteau 393 New Bedford, MA
If they’re stainless you could try using spotless stainless which I believe is a citric acid passivation.
Oct 6, 2007
1,164
Hunter H30 1982 Chicago IL
Rust on keel bolts and nuts is concerning. They should be 316 stainless so they don’t rust. Lower grade 304 stainless can get surface rust quickly, as would ordinary steel. I agree with dlochner that epoxy would be a bad choice. Stainless steel is best left exposed to the air. If they’re not stainless, I would second dlochner’s recommendation of CRC or BoeShield.
Photos would help us better understand the condition.
Likes: NYSail
dLj
Mar 23, 2017
4,780
Please provide pictures.
Good advice above - but I'd like to see these before commenting further.
dj
Jan 4, 2006
7,443
Good catch. We just assume everybody has SS keel bolts and they always have a bit of discolourization on them. Are OP's just discoloured or really rusty ?
