Keel bolt and plate
12
Hunter 34 Panama City Fl
1984 34 ft Hunter...Aft keel bolt support plate is flaking apart.. I need a replacement plate and what the torque of the bolt is suppose to be. Local manufacture might work if i know what material it is suppose to be.
Dec 2, 1999
15,184
You may want to search the archives for an answer. You can also check with Hunter.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
If you look at the Hunter website model information section they do have a spreadsheet with all the specifications for the keel bolts on each model. If the plate is rusted away you might want to inspect the bolts before replacing the plate.
good luck, Bob
