Agree with Joe
I totally agree with Joe, the leak(s) is/are most likely not associated with your keel bolts. Likely sources of unwanted leakage are, in order of likelyhood: portholes, mast cradle bolts (including thru holes for wiring), toe rail, chain plates, hatch. Wash downs always produce water in the bilge. These leaks generally appear around the sliding companionway hatch, hatch boards, lazaret lids (in particular the aft lazaret). Thanks Joe for the powder tracing ... good idea. I have used water with food coloring at suspect areas to locate leak sources. Another way to find leaks, especially the toe rail variety, is to visually inspect the screws/bolts (from inside the cabin) holding the rails in place. Look for drips or droplets during a rain storm. They will generally appear at the tip of the bolt or screw.
