Well, I finally did it...I got all the materials together (at the same time for a change) and went to town drilling and filling my mast step area on deck.
For thoses who don't know, my mast is unstepped and I have a Garhauer-brand base plate that I am installing under my mast step so that I can run my halyards back to the cockpit. The pre-existing holes for the step mount-bolts show signs of water intrusion, plus I just want to bed the step properly and securely. I also have one or two small areas next to the step that sound hollow when tapped with a hammer that I felt needed to be epoxy-filled.
Anyhow, I have been following the pbase.com articles reccommended by Mainesail in conjunction with the West Epoxy guides and John Cherubini Jr's "Diana-of-Burlington" blog. Everything worked as advertised, including getting the epoxy to a "mayonnaise-like consistency" with collidal silica powder. I was actually surprised how much silica it took to get the proper thickness! Initially, I thought that I had added too much at first (it was windy and a little too much was carried out of the container) but it ended-up just perfect.
The best tip is the placing of duct tape around the hole on deck to eliminate alot of clean-up afterwards. Cherubini was also right about cored fiberglass really sucking up the injected epoxy. I kept running 'downstairs' to see if epoxy was leaking out of anywhere because I must have pumped a good five or six syringes-full of epoxy into my hollow-sounding core. Nothing I could see however. I'll investigate further today before I do any more. I want to make sure I'm not just pumping epoxy into the space between the deck and the headliner. No need to waste that expensive epoxy resin! The WEST-brand measured pumps really take the guesswork out of the epoxy resin and hardener mixing and all the different additives that WEST makes for their epoxy makes using it really nice. And this is a guy that never worked with this material before. (Now, if I could only learn to weld I'd be unstoppable!)
Oh, another good tip I learned by experience: To avoid chipping gelcoat/fiberglass when enlarging a hole use a step drill (or unibit) rather than just using a larger drill bit. The step drill bit doesn't 'bite' the gelcoat like the tip of a sharp drill. That being said, a brad-point bit makes a nice NEW hole in fiberglass (make sure to run the bit backwards for a bit at first to get a good starter dimple).
Now I feel confident about spending some more time drilling and filling all the suspect areas on my deck (thankfully, not many..maybe two or three small spots near the mast step). I am also going to epoxy fill the top of my rudder near where the rudder post goes into it because I suspect that to be the source of some water intrusion. The rest of the rudder will be refoamed with two-part foam (8lb foam) and then reglassed....but I digress...
The next step will be sanding flat the epoxy, drilling and countersinking my new epoxy filled holes, and then using a combo of 3M-4200 and Butyl tape to attach/seal the mast base plate and step. Photos soon to follow! Once the step is in I only have my LED bulbs to install on my mast-mounted nav lights, hard-wiring the windvane, and a good ops check of everything to make sure it works and then up the mast goes!
Other than the expense of epoxy and supplies (metal bucket, mixing sticks, syringes, duct tape, dremel bits, etc...) actually working with the epoxy was very rewarding. And as they say, when you do it yourself the tools are free.
