The continuing tank story
When I removed my tank, there were no straps holding it in place. After the tabbing in the v-berth was removed, the tank was loose. It had to be cut and folded together to slide it out, though. Also, in preperation for installing a new tank, I have removed the side of the v-berth. An abrasive cutting wheel on a drill worked the best. This gives lots of access to work on installing the tank. An interesting discovery, There is a very large closed in area under the raised portion of the cabin sole. I'm thinking of putting an access panel to open it up for storage.As far as my plans for a new tank in the original location, I talked to Ronco, and they would require me to pay for the creation of a mold, (probably approx. $500) but after that the tank would be cheap. This would only work if there are several of you who want to help split the cost of a mold. (e-mail me at edkennedy@netzero.net). The other alternative is to have a tank made of heat welded flat pieces of polyethlene. Ronco won't make these, but they told me that this would probably cost approx $250.If anybody knows a supplier of welded polyethlene tanks, please respond or e-mail me.Well, thanks for reading this long response. I'm taking a break from this project for the holidays, but I will tell more next year.
