Just in: Gas struts for refrig lids and engine compartments
1,865
Re: Just in: Gas struts for refrig lids and engine compartme
Hi Phil:
This caught my attention as I've been looking for something like this for 3 years to hold up the chart table lid on my 44DS. The boat came with a spring loaded arm which failed the first year. These arms shown here are a bit long for what I need. I need something around 1 FT extended that will hold up the chart table lid, then stow folded down somehow when the lid is closed. I've looked everywhere with no luck. Do you see anything in stock or orderable which might work? If you like, I can send a pic.
Thanks
Jack
Jan 30, 2008
121
Hunter 33 -
Cockpit locker
We have been looking for something to hold up the cockpit locker lid. Do you think something like this would be long enough to get the lid fully open? I did see the full extension to be 20" and will get some measurements this weekend.
anyone ever try to refit this?
J&R
Feb 16, 2012
198
Hunter 45 CC Alamitos Bay, Long Beach
Re: Cockpit locker
Phil,
Will they work as replacements for the lid on the exterior propane locker on a 2006 Hunter 45 Center Cockpit?
Jeff
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
Rick486: I think we have a replacement for the chart table arm you're missing.
We have two sizes and the full extension is either 15" or 20". One of the 20" models has a 100 lbs lift capacity so it _could_ be used for a lazarette lid, if it fits and can be mounted.
Jeff, was there an OEM arm on your propane locker?
Just so we don't clog the forums with too much of this stuff, you can also contact me at http://shop.hunterowners.com/cs/index.php?a=add&r=forum
May 9, 2012
35
Hunter 380 Alameda
FYI, the hunter 380 model numbers are:
SL3-20 for the fridge/freezer
SL25-30 for the engine compartment
