Just How Good Are Hunters?
59
Hunter 1990 Hunter 30 Kentucky Lake
I realize I am asking a biased audience but I know many here have owned other makes of sailboat. I have only limited sailing experience but I have been so impressed with my H240 vs the other boats on the lake. I know Hunter are considered "production boats" but you get so much boat for the price and they seem to sail as fast as anything in the same class yet the simplicity of the boat allows a beginner like me to sail like a pro. What am I missing? Where do Hunters not stack up to the much more expensive competition?
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
When crossing an ocean. Hunters can do it and do but most prefer a blue water boat. Many can argue this subject but Hunters are not "blue water boats." I love mine and it is great for coastal cruising. However, I would not want to cross an ocean in it.
Les
May 8, 2004
375
Hunter 27 Bellingham, WA
Consider this that Ferrari cars are "production cars" even though they may make only twenty-four of that model. I'm in the September of my years now and have grown up with sailboats since the late nineteen fifties. I've had ten new boats, the last five have been Hunters because of the quality of construction that I have observed. They are a good company and made in America.
Years ago at the beginning of the dawn of fiberglass right after WWII, sailboats were hulls with decks and minimal interiors. When you looked under the interior seats of the Cal there was raw fiberglass. The hot boat at that time was the plywood Thunderbird or T-bird, an excellent 26 footer that could be built at home.
It took a while for sail boat companies to learn how to design and use fiberglass. And building the interior was a work of art with each piece of wood being measure for that individual boat. Some companies still build their boats that way but it is labor intensified.
Some of our boat companies couldn't compete with the Asian boat companies with their cheaper labor and we began to import Fugis, Yamaha's, etc. So our boat companies responded with learning how to build boats like old Ford cars with every piece fitting every boat on the line. A company could cut ten pieces for ten boats at one time and have them all fit. Hunter was one of those companies that lead the way in modern day boat construction.
But one of the things that convinced me to buy Hunter was their program of checking back with owners and asking what is working--what is not working. Then they would make adjustments in the plant and construction of their new models. I have watch improvements on all of my five Hunters. I suspect the new models are even better and have passed me by. "How can we make it better" seems to be the mantra of Hunter company and indeed, they have been one of the most innovating boat companies during the past twenty five years. Look at the B and R rid, roller furling mains and jibs, sugar scoop sterns, "tourist" seats in the stern, and the list goes on. Even where you can't see things they made improvements such as all plastic tankage or all through hull fittings in one place accessible for checking. Some of these same innovations and/or improvements you cannot find on some of the more expensive boats....however individual perception is a fascinating study.
To complete my point, I drive a Subaru Forester which gets me to the store quite well. Would I like a Ferrari? I'm sure I would have fun going to the store in one but I doubt if it would get me there quicker (we have stop lights in my town) or anymore comfortable..... I suspect I would enjoy the purr of the Ferrari motor or the smell of the interior. I suspect I could enjoy sailing an Oyster sailboat but quite frankly I am in love with my Hunter 27. At my age it is a delight to sail and I can sail it by myself. And I don't have to repair or add items to make it sailable. It may be that the owner of a Ferrari will look down at me as might the owner of an Oyster. But the end result is that I'm having as much fun as they are sailing.
So if you think your H240 is well made, you are correct. If you think your H240 is a good investment, you probably are correct as well. The end result is how much you enjoy sailing and cruising in your boat. I hope you get as much satisfaction from your Hunter as I do mind.
I wish you well. By the way, I'm eighty in years and have sail many, many boats over the years. I still think of my Hunter 27 as a MGA of the boating world....a fun boat.
Jul 19, 2013
186
Hunter 33 New Orleans
I am new here and just purchased a 2006 Hunter 33.1. I have owned an ODay 25, a Hooks Marine Custom 34,Heavy Bluewater Boat. and also own a Nimble Nomad. Sailing for over 20 years. I do my own work and have read several books on boat construction. I was a Machinist Mate in the Navy and operated a 1200 lb Super Heated Steam Main Propulsion engine room.
A Hunter is a production boat which seems to have it's fair share of detractors but from what I have seen and inspected it is a well built boat. The boat I bought had a owners manual which detailed every system on board in detail, which is not something I saw on any other boat, I also found the manual on line. All thru hulls are centrally located easy to close which is what you should do when you leave the boat. I found all the equipment installed up to the intended and installed properly. BTW I am perfectly qualified to survey the boat myself but hired a qualified survey to do a survey and he found no construction issues and only minor gear issues. I had used the same surveyor last week on a Catalina 30 which I walked away from at a cost of $800.00 for survey and lift, money well spent. Bang for the buck the boat is a great boat. As on all boats you have to balance the boat you buy with the intended use and your skill level.
Good luck on your hunt for a boat, sometimes it takes time to find the boat that loves you.
Jim
May 24, 2004
7,169
CC 30 South Florida
The Italians do not use Ferraris to go to the store either, they keep them in the garage and drive a Fiat. Each engine is hand assembled by a single highly trained and experienced individual. The seats are hancrafted from selected cuts of leather. That is not a production automobile. The use of computers has revolutionized manufacturing processes, we can now reach tolerances that before were to expensive to achieve. The difference observed between specialty builders and production manufacturers mostly rest in the quality of the materials being used and the quality controls. While the first may accept the cost of having to redo a job the other may decide to overlook it. Ferrari engine blocks undergo rigorous testing with a rather large percentage being scrapped and the metal recycled. The quality on production automobiles and boats has been improving but there are still a number of lemons reaching the marketplace. Don't get me wrong Hunter puts out a "Ferrari" of a design, uses good matrials and good components and price the boats fairly. Production errors that do not affect the safety of the boat are routinely overlooked but that is the tradeoff we are willing to accept between Price and Quality.
-na -NA Anywhere USA
The Hunter water ballast sailboats were designed for the trailerable sailor as I was very much involved with them from the start. The 23.5 is my baby and I outsold all other dealers of the 240. I also sold Catalina, Beneteau, ComPac, Precision, MacGregor and many others over the years. I have heard all the Fiddlesticks about boats and so on. All to include the Hunters have their good points. When you say this is a blue water boat of course referencing the 240, it was not designed to cross an ocean. As to a productin boat, well guess what, so are the rest of the crowd as I have been in all the plants except for the MacGregor. If the two of you want to contact me, please feel free thru the forum email and I will be glad to help. My info is based on information and experience.
crazy dave condon
FredV
Oct 16, 2011
148
Hunter 37-cutter Philadelphia, PA
Not "blue water boats"? Don't know about the newer Hunters, but I bought a Cherubini 37-C specifically to be my "blue water boat". It's built like a tank and reported by far-too-many-to-ignore owners as surprisingly fast.
I wouldn't think twice about cruising the oceans in Fred V - the boat is fine, it's the captain that's questionable!
Hunter 37 C sloop Punta Gorda FL
We are very comfortable at sea in our 37c. Unfortunately you can't buy a new one.
Jun 7, 2012
86
Hunter 456 Port Canaveral
Hunter Quality
I spent the last year repairing and replacing parts on my 2002 H456. Eighty percent done by professionals and everyone of them from the diesel mechanic to the electrical engineer to the plumber has commented on how well this boat is built and with quality parts. Just be prepared to add 50K of offshore equipment and go where you want to go.
Aug 5, 2013
3
Hunter 36 Deale
A Biased Reply
I have a 2005 Hunter 36. In my opinion, the 36 is one of the best designed boats Hunter has made. I agree that the company does listen to owners and make changes. Lately it is their downfall. Go to the sail show - I don't think anyone leaves the dock. No storage space, difficult to do things underway, all designed to be at the marina not on the hook. Finding the right boat boat is like buying house. You know when you're "home". New is just as much of a pain as not, still bugs to work through. Our friends spend more time fixing their brand new Beneteau than sailing. I also agree I would not take our boat blue water. Not because she isn't seaworthy, but because of the keel. She is perfect for the coastal cruising that we do. Easy to single hand, perfect for two to be very comfortable, but big enough for friends to join us every now and then.
Oct 4, 2010
56
Hunter 376 Kent Island, MD
CRBKT 1, I looked at all kinds of boats from Fla,to Apls, to New Eng. in the 37-40 range. I stayed away from Hunters 'cuz of my late 70's experience w/ them where they were a "Package Boat": carpeting not only on the cabin sole but UP THE BULKHEADS & ACROSS THE CEILING !!! REALLY!!, & a plastic "garbage bag" filled w/ 2 PFDS, some lines & a couple other items that made it; "Ready To Sail". I bought an Ericson back then & loved the John Holland designs & quality materials ( real, thick teak not vinyl over plywood ) & craftsmanship. Had it 30+years. Anywho, I had to swallow my pride & got a rude come-uppance. I bought a 1997 Hunter 376!! : o Learned it had been The Boat of the Year!! I am constantly comparing it w/ similar Catalinas ( who also have come a long way since the 70's) & Benateaus,etc. $ for $, spaciousness, brightness below ( Benateaus are "bat caves"), comfort, ( the pass-thru stern stateroom ( 2 doors, to galley & head ) surpass the other boats. I'm a USNA Offshore Instructor & USPS Safety Officer. I agree w/ my fellow sailors that Hunters are NOT Offshore boats, but Coastal Cruisers. Mine has been to Maine & back & all over the Chesapeake Bay, whose summer squalls can get pretty nasty. They're not Tartans, nor Sabres, but if you're not going Offshore, they're a GREAT boat. "Fair Winds & Following Seas...." " Murph "
Aug 23, 2009
361
Hunter 30 Middle River MD
I have one of those 1970's package Hunters, a 1977 30 with the carpet everywhere. These boats were built to meet a price point and they did. They were well made and still do what they were intended to do. Amazingly much of that carpet is intact and as she is a dry boat not moldy and while not as attractive as teak, its ok. I sail the boat not its interior and more than 36 years after she left the factory she is still a fast boat for her class. My crew member who owns a Catalina 30 marvels over the standing room and comfort below. She is no Ferrari, she will never cross an ocean but she gets me a round the Cheaspeake and the Delaware and that's what I bought her for.
Apr 29, 2010
25
Hunter 36 nj
My first boat was an 85 Hunter 25.5. I also looked at the 24 foot ODay but liiked the separate bulkhead going into the V berth on the Hunter, making it seem bigger. . It only drew 3'3', you needed a porta potty but it sailed well. When looking for a newer boat, I was directed to both Catalina and Beneteau. Both nice boats but I liked the style and the amount of light coming thru on the Hunter along with the lighter wood. The boat sails great, even in higher winds and the in-mast furling doesn't cost you a lot of speed. I frequently get over 7 knots and topped out at 8.4 kts. It does have the North Sails. Boats are personal preference but I'll put the Hunter up there with the other producton boats anyday.
