My huband and I just got the survey back for a 1985 Hunter 34 we are planning on purchasing. While the boat has received a rating of "Above Average" there are some defeciencies that will need to be addressed. I am hoping that others may have had experience with these repairs and could offer some insight.1. Moisture meter read high in the deck area around mast step and halyard winches. However, there is no cracking, sagging, sponginess or water stains in these areas. How severe could this be? Could it be remedied with rebedding with caulk?2. The discharge hoses and clamps should be replaced with good hoses. Is this a repair that you can do yourself or is it just too icky? How do you find out how much hose you need?3. For the hot water system that while it has a bronze pressure relief valve on the tank that it should have unrestricted an un-reduced overboard discharge. Does this mean a new valve installed? Again, is it hard to do?4. The Maxwell 2sp #24ST need new bearings and races. Is it possible to use any two speed winch repair kit or does it have to be Maxwell?5. The standing rigging needs to be tuned. Is there a tuning guide for the Hunter 34? I have never sailed a boat with the crossed lower shrouds.6. The survey recommends, at the next haul out, replace packing gland boot, install a shaft zinc, replacement of the standing rigging and all fittings. Any thoughts on attempting these repairs on our own?7. Recommends replacement of heat exchanger hoses from the water heater. Can this repair be attempted on our own?8. Flush water holding tanks with heavy bleach solution. How do you do this?That seems like plenty of questions for one post. I am looking forward to hearing from any of you helpful folks out there.
