I just added a third battery into my 1990 Catalina 30 MKII. If anyone is interested in doing this project I can give you some info on it. It was actually an easy job and it didn't cost too terribly much.I put the third battery into the storage area under the rear quarterberth. I ran the negative cable from the battery box under the starbard part of the salon to the rear storage area by running it under the nav station. I just pulled the hot lead for battery one out of the battery box and ran it to the rear storage area. The third battery, in the quaterberth area, is a dedicated starting battery and it is on #1. #2 is 2 group 27 deep cycles run in parrellel. I like the setup and it seems to be working great.
