Joker Valve
Stuart
Hi Peggy, bought your book. Reads great. Going to replace the joker valve, see where it is in the diaghram in your book. Is it a fairly straightforward replacement, or any twists & turns I'll need to take? Thanks,
Peggie Hall/HeadMistress
It couldn't be simpler...
Remove the head discharge fitting, remove the joker valve, put the new valve in, replace the head discharge fitting. Just be sure you don't overtighten the fitting when you put it back, 'cuz the flange on the joker valve is also the gasket between the pump and the fitting. It'll leak if it's over-tightened. As long as you're doing toilet maintenance, now would also be good a time to lubricatate properly. You'll also find instructions for doing that in my book.
Paul Akers
Just wash your hands afterward...
...before you make your sandwich for lunch :)
