Stuart
Hi Peggy,Tried to replace the joker valve in our Jobson head (1999 Hunter 340) this weekend. Symptom was some discharge of water coming back into the bowl from the discharge hose after pumping out (was 3 - 4" in the bowl the weekends following our use the prior weekends).The replacement joker valve I'd purchased was the wrong size and the marine store didn't have the right size (par for a lot of my projects, having to go back & forth for various parts). Couldn't find a model number on the head to order the right size, so I'll call Hunter this week to see what model we have and then either order from Jobco or the marine store. Anyway, while trying to replace the existing joker valve until I get the new one. I had a hard time lining up the connection to screw the hose to the head. Did a couple of times, and it looked ok ... but when I pumped to test or added water to the head, discharge came leaking out of the connection (hose to head connection). Now I also cannot recall if I was putting the joker valve back in the right way (pointy end into the hose). Read where you said not to tighten too tight, so I kept the connection loose. Is there some secret to making a watertight connection ... or did I just fail to line it up correctly.Also, our Hunter is a 1999, per your book, the head could use a rebuild with new seals, etc. Should we replace the hoses as well? We use fairly regularly on weekends May through October. Thanks (as usual).
