Joker valve replacement.
62
Hunter 35 PENSACOLA, FL
To All
Prior to the actual change out of the joker valve is there an easy way to remove the liquid in the standing pipe above the joker valve ?? My pipe is about 15 inches high.
rd
Dec 2, 1997
9,010
- - LIttle Rock
Use the dry mode
Any toilet that's working anywhere near factory spec can move water/bowl contents up to 4' in the dry mode...so your toilet should have no trouble moving it a mere 15". About 1/2 cup or less may be left, so put a plastic bag or disposable pie pan under the fitting before you remove it. And it would prob'ly be a good idea if you put a lot of clean water through the system first.
