centerline, do you have a backstay and is it adjustable? If yes to both... I can't see what use the quick-release on the forestay would be.
On our boat we don't have a backstay, so the sidestays are positioned back of abeam the mast step for 3-point support.
Last year I was all gung-ho for putting a quick-release on our forestay... til a friend showed me that I could pull the mast forward enough with the jib halyard (which we use to raise the mast anyway) to attach the forestay to the bow. So, that revelation saved me about $40...
I guess the only other use of the quick-release is being able to release rig tension when the sails are down, but then the mast might flop a bit which I think is harder on everything than simply remaining tensioned.
Sumner,
my turnbuckle when properly tentioned is 8" pin to pin. when extended to connect and disconnect it is a bit over 9.5 inches
Kenn,
from your avatar photo it looks like you have a fractional rig. so I suppose its possible for you to get a bit of bend from the mast to make the connection to the stemhead fitting. with the masthead rig i have, I am pulling directly against the tension on the back stay. I dont have any give. when connecting to the stemhead, I pull down hard on the gin pole to get the anchor pin in, and then after connecting, I have to tighten my forestay turnbuckle about 1.5-2" inches to tension the rigging. I have it adjusted so that tightening the forestay will pull the backstay and the shrouds to the proper tension, without further fiddling with the other stays.
the advantage would be that i would be about 5 minutes quicker and less stress on my wrists and fingers when tightning up the turnbuckle.... just attach it and snap it closed and put the safety pin in.... AND with another hole in the adjuster to shorten the rigging to, after I sail for a few hours and the rigging and hull streches a bit and loosens up, I could take the slack out of it by going to another hole.... easier than getting out the wrenches and tightening the turnbuckle.
and my forestay turnbuckle has a bit of a rough spot in it so if i need to spend a some money to replace it, im not opposed to spend a bit extra to get an upgrade.... i just need to decide on what is the better option.
(I have broken both of my thumbs within the last two years and my dexterity isnt what it used to be, and the little ring ding pin keepers are a real basta*d for me... so a snap closed device would be better in every respect)
