The only thing I'm not a big fan of when stepping the mast is the super tension we need to exert on the system to get the forestay pinned. It seems excessive but when all is said and done it all seems right with the world. We are however talking about the Johnson lever setup after each time we finally get the pin in.
What I don't really want though is to start moving stuff around on the mast too much and I got to thinking - is it the side shrouds we're fighting against or the back stay or a combination of both? If it was the back stay could a guy not install a Johnson lever on it instead? It'd give just enough extra room to wiggle the pin in up front and then would snug everything down.
I'm pretty sure the shrouds are really where the tension is but had to ask the question out loud to get it out of my head. And really - if the solution was this simple I'd have read about it by now - or it'd be factory installed! Thanks for entertaining my musing however uninformed it may be...
